12 Mars 2010 à 03:57:28
13633 Messages dans 2137 Fils de discussion par 2725 Membres
Dernier membre: Vegass
Dernier firmware du Cowon O2 +  Astuces Cowon et iRiver sur le portail du multimédia portable
| |-+  Cowon O2
| | |-+  Dernier firmware du Cowon O2
Pages: 1 [2] 3 Bas de page Imprimer
Auteur Fil de discussion: Dernier firmware du Cowon O2  (Lu 8274 fois)
« Répondre #15 le: 22 Janvier 2009 à 10:21:52 »
Le firmware 1.24 est sorti c'est un version bêta j'ai testé un Hd Divx 5/6 1280 x720 qui avait tendance à ramer et un décalage sur le son il passe nikel maintenant  Sunny
Freeman
Actif
~Smile to Life~
« Répondre #16 le: 05 Février 2009 à 20:03:56 »
Le firmware 1.25 est sorti avec une longue liste d'améliorations Affraid (Téléchargement disponible sur le 1er post).
Video mode
    - Improved video playback performance of HD Xvid, DivX 5, DivX 6 files  (be able to play high resolution files that are over 1280*720p)
    - Added picture mode settings: vivid mode / standard mode
    - Improved stability of performance of some faulty video files that contain AC3 audio codec.
    - Moved position of volume icon in TV-out mode.
    - Fixed the error that movie file was playing without video after preview picture files in Brower.
    - Fixed the error that movie files are not playing properly in TV-out mode, if wide resolution of files is 1440 pixels.
Music Mode
    - Fixed the error that some music file lyric passed faster then it supposed to when files played from recent files.
    - Improved video resolution of album art, which is high resolution, of mp3 files.
    - Fixed the error that while some music files, which contain album art, are playing, screen changes to menu and back to music mode and karaoke lyric is overlapped on Meta information.
    - Changed position of album art.
Pictures mode
    - Changed to stop when you press previous or next button in slide show mode.
    - Fixed the error that slice show is irregularly down when previous or next button is pressed.
Documents mode
    - Improved performance of controlling scroll bar when it didn’t work right in some part of irregular files.
    - Improved performance of controlling scroll bar when displaying small size files.
Timer
    - Fixed the error that time recording was not working properly when it is set as built-in Mic.
User program
    - Calculator: fixed the error that value was showing as 5.900000000000001 when calculate 2.09+3.
    - Scientific calculator: fixed error when calculates number with π.
« Dernière édition: 05 Février 2009 à 20:09:49 par Freeman » Journalisée
Denon AH-D5000 avec Black Dragon 10' Grin (M-6)
« Répondre #17 le: 20 Mars 2009 à 15:13:07 »
Une nouvelle version du 1.27 du firmware est arrivé !!!
Arrow O2PMP_V1_27.zip
Voici les améliorations :
Mode Vidéo
Ok Ajout d'une répétition de section
Ok Ajout d'un bouton pour ajuster la vitesse de lecture sur l'écran vidéo.
Ok Ajout d'une option pour ajuster la position du sous-titrage
Ok Amélioration de la vitesse de recherche des fichiers ASF et WMV qui comportent un index endommagé.
Ok Correction de la lecture des fichiers à petits bitrates (10fps) qui étaient joués plus lentement que prévu.
Ok Correction du niveau de luminosité, qui restait sombre même en poisitionnant la brillance sur le niveau le plus élevé.
Ok Correction de lecture sur certains fichiers MPEG4 (Xvid, DivX 5, DivX6) qui ne s'affichaient pas correctement à certains moments.
Mode Images
Ok Amélioration de la qualité d'affichage d'image  lors d'un zoom de 150% à 200%.
Ok Amélioration de la vitesse de réation des mouvements haut, bas, droit, gauche et diagonale.
Ok Correction de la disparition plus rapide du menu popup quand on clique plusieur fois sur le bouton des favoris.
Ok Correction du zoom avant, arrière et déplacement qui se trouvait inopérant lors d'une pause et relecture de musique dans le mode multi-tâche (musique et image).
Mode Documents
Ok Evolution pour passer la page suivante ou précédente quand on se déplace à doite ou à gauche de l'écran.
Ok Correction de l'arrêt de l'auto scroll quand on passe en plein écran pour cacher les contrôle.
Ok Correction de l'affichage des fontes des fichiers (affichage incomplet) lorsque l'on passe des pages. (skip)
Ok Correction de l'apparition de point en bas de l'écran quand la couleur est changée en noir.
Langage et caractères
Ok Ajout le l'encodage Thai (Settings > display > appearance > system language )
Ok Support du language Thai dans le browser.
Ok Correction des sous-titres Hebreu et Arabe afin de les afficher de droite vers la gauche.
Programme Utilisateur (User Program)
Ok Affichage de la taille des fichier arrondi à deux décimales.
Ok Ajout d'une option pour ordonner l'affichage de la liste des programmes utilisateurs
« Répondre #18 le: 20 Mars 2009 à 18:27:30 »
Merci je vais installer ce firmware j'avais pas mis à jour mon 02 depuis la version 1.24 je vais tester ces améliorations  Wink2 .
« Répondre #19 le: 14 Avril 2009 à 12:10:19 »
Une version V1.28 béta coréenne est disponible pour notre Cowon O2, avec l'ajout d'une visionneuse de manga et d'un scandisk.
Comic Viewer
Ok A cartoon image file content, add the ability to conveniently view
Ok Minimap, Automatic Wrapping, read orientation, page alignment feature support
Ok Comics work playing the file
Disk check
Ok Settings> System> disk check run on
Ok Device is down for no reason by the behavior of unstable
Ok If you have an error in the file system, run ScanDisk, you are automatically modified.
Ok Connect the adapter and run the disk check, please be sure when.
Video mode
Ok The index is damaged, the ASF ASF jaesaenghu modify the phenomenon navigation is slow
Ok Movies Movies Subtitles jaesaengjung pop-up was cleared and open it again does not modify the symptoms
Music mode
Ok Apple Lossless audio codec music files (the extension m4a, mp4) to improve the compatibility of
Documents mode
Ok Text Viewer jangpyeonggap If you change the setting in Tru taip abnormal phenomena modify the output was
Téléchargement : O2_V1_28.zip
Dictionnaire pour les firmwares >= V1.14 Arrow COWON_PowerDic2_O2_20081126.zip
Dictionnaire pour les firmwares < V1.14 Arrow COWON_PoweDic_O2_20080930.zip
Source : Cowon Corée
« Répondre #20 le: 23 Avril 2009 à 14:53:09 »
Voila la version 1.29 internationnale est arrivée !!! Sunny
Voici le détails des améliorations :
Comic viewer (Visionneuse de Comic)
Ok Ajout d'une fonctionnalité bandes dessinées pour lire des dossiers d'image de bandes dessinées plus facilement
Ok Support d'une mini map, de l'auto scrolling, direction de lecture, fonctionnalité de redimentionnement à la fenêtre.
Ok La fonctionnalité à été ajoutée dans Utilities > Comics.
Disk check (Vérification de disque)
Ok Pour y accéder aller sur : Setup > system > disk check.
Ok Vous pouvez corriger des erreurs système en exécutant l'outil disk check quand il y a des erreurs ou quand votre système vous parait instable.
Ok L'appareil doit être branché sur le secteur pendant que la vérification de disque.
Video mode (Mode vidéo)
Ok Correction de lenteur sur la recherche des fichiers ASF après une lecteure de fichiers ASF endomagés.
Ok Correction de la disparition d'un sous-titre après avoir ouvert une fenêtre pop up pendant la lecture d'une vidéo.
Ok Correction de la lecture sans son de certains fichiers AVI quand le codec audio est en WMA.
Music mode (Mode de musique)
Ok Compatibilité améliorée avec le codec audio sans perte d'Apple (m4a, mp4).
Documents mode (Mode Documents)
Ok Correction de l'erreur d'affichage quand la valeur de ratio qui est en true type est ajustée.
User program (Programmes Utilisateur)
Ok Calculatrice scientifique : Correction de l'erreur quand 7E-06 STO est changé avec 7e-06 après avoir appuyé sur RES
Ok Calculatrice scientifique : Correction de l'erreur survenant lors d'une multiplication par -1
Ok Bloc Note (Notepad) : Stabilisation du système quand il n'y a pas suffisament de mémoire de libre.
Téléchargement Arrow O2PMP_V1_29.zip
« Répondre #21 le: 24 Avril 2009 à 13:19:38 »
Merci Odeyssus pour la news en tout cas terrible ce comic viewer je pourrais visionner mes scan comme sur le Cowon Q5W .
« Répondre #22 le: 11 Mai 2009 à 11:24:12 »
Un nouveau firmware version 1.31 est désormais disponible pour notre Cowon O2 ! Sunny
Voici le détail des améliorations par rapport à la version précédente :
Stabilisation du système de fichiers
Ok L'installation de ce firmware est recommandée pour pour améliorer la stabilisation de l'utilisation de votre appareil.
Mode Vidéo
Ok Correction du plantage lorsque la police du sous-titre de la vidéo est en true type.
Ok Correction de l'erreur d'affichage de gauche à droite des sous-titres en hébreu et en arabe lorsque la police de la vidéo est en true type.
Mode Documents
Ok Correction de l'erreur d'affichage de gauche à droite pour les textes en hébreu et en arabe.
Téléchargement Arrow O2PMP_V1_31.zip
S@ber_Chopper
Actif
D@rk-S@ber_AKG K 702
« Répondre #23 le: 10 Juin 2009 à 21:18:29 »
Cowon a sortie la mise à jour du O², et sont passés en V.1.33 maintenant...
« Répondre #24 le: 10 Juin 2009 à 22:53:05 »
Oui, bien vu S@aber_Chopper ! Ils ont sortit ça à 17h30 aujourd'hui et c'est disponible uniquement sur leur site coréen. Sunny
Enfin pour l'instant. Smiley
Movie Player
Ok Améloration de la qualité vidéo des vidéos de résolution 480x272
(la qualité d'affichage en 480x272 permet d'améliorer les vidéos Internet afin de pourvoir lire le blackboard)
Music Player
Ok Correction d'un phénomène anormal qui se produisait sur les Album Art en 8bit jpg.
Ok Stabilisation de la lecture audio Musepack (s'applique au codec Musepack SV8 final)
Photos / Visionneuse de Manga
Ok Correction du phénormène de l'écran qui clignote pendant l'on joue une musique
Ok Stabilisation des symptomes liée à l'execution concurente pendant la lecture d'une musique en arrière plan.
Ok Paramètrage d'une résolution 960x544 correspondant à une demi page de bande dessinée afin d'améliorer la qualité.
DMB Player
Ok Ajout des réglage de fréquence pour l'Europe
Ok Support du DMB Novégien
Enregistrement Microphone
Ok Correction des symptômes d'enregistrement comme le bruit
Ok Ajout d'un paramètrage de la qualité de son, haute qualité / basse qualité
Support des Langues
Ok Ajout du suédois
Téléchargement Arrow O2_V1_33.zip
« Répondre #25 le: 27 Juin 2009 à 15:29:26 »
Malgrès les améliorations de fimwares, je n'arrive pas à un support de codec du niveau du Cowon Q5W.
Je n'ai pas constaté d'améliorations significatives avec mes fichiers de tests HD 720p en wmv. (ça saccade toujours)
Cela dit, j'ai un fichier AVI au format 1280p :
Video: Xvid 1280x720 23.98fps
Audio: MPEG Audio Layer 3 32000Hz stereo 128Kbps
Et ce format fonctionne parfaitement bien sur le Cowon O2, alors que c'est impossible de le lire sur mon Cowon Q5W.
Bref c'est vrai le Cowon O2 supporte bien du 1280p ! Mais au format Xvid... il faut oublier le wmv.
« Répondre #26 le: 07 Août 2009 à 23:31:46 »
Le firmware V1.34 Beta vient d'arriver sur le Cowon O2 en corée. Voici le détail des modifications apportées.
Ca date juste d'aujourd'hui et vous en avez la primeur !
Movie Player
Ok Correction des problemes de clignotement sur les vidéos encodée en WMV9 Simple Profile
(Certains du contenu de l'étude / Edited clignotants phénomène)
Ok Amélioration de la prise en charge de la lecture des codecs AVI-on pour les fichier qui comportent des entête endommagés
Ok Amélioration de la capacité à gérer la couleur du sous-titre
Ok Correction de l'affichage de durée totale et des comportements anormaux de certains d'ASF / WMV.
Ok Amélioration de la stabilité du décodeur MPEG4
(Correction de certains phénomènes vidéo DivX)
Music Player
Ok Support du format de l'album: JPG avec en plus le support des format d'images BMP / PNG / GIF / TIFF
Ok Support de la résolution des Album art : JPG 5900 pixels maximum, ou d'autres formats, jusqu'à 500 méga-pixel
Ok Amélioration de la stabilité lors de la lecture MP3 qui contient l'album
Ok Quelques améliorations de la stabilité des MP3 taggés en ID3
(L'entête du MP3 ID3 Tag est peuplé avec un 0 si le comportement est anormal)
Photos / Manga Viewer
Ok Support du format BMP 16 bits RGB565
Ok Améloration de la rapidité de chargement des fichiers
Ok Correction du comportement anormal sur la première image
Ok Améloration du rendu de certains fichiers JPEG sombre ou avec des couleurs vives
Explorateur de fichiers
Ok Faites glisser scroll grâce à au stylet
Dictionnaire électronique
Ok Support du nombre de mots dans la liste, le nombre actuel étant de 200-500 mots (dictionnaire électronique manuel modifié)
Ok Modification du problème d'affichage : quand vous touchiez le haut de la page 00, on avancait au titre titre affichée dans l'image sur le côté gauche.
Les derniers fichiers
Ok Correction du probleme d'édition simulatanée de texte alors que l'on est dans la liste des fichiers de la musique de la carte SD
Fonction Mot de passe
Ok Définir le mot de passe pour restreindre l'utilisation des fonctions d'appareils
(USB pour se connecter à un PC via un disque amovible, l'appareil utilisé pour limiter l'accès)
Ok Apparition du menu [Système> Add-ons] après la mise en place du mot de passe
Ok Un mot de passe de 1-8 chiffres peut être entré
Ok Mot de passe pour se connecter à un disque dur via USB
Attention lorsque vous supprimez un fichier dans le dossier racine, le mot de passe est stocké dans passwd.sys
Plus
Ok Correction de l'affichage des éléments de l'horloge quand vous modifier la police au bas de la barre selon le type de police.
Téléchargement Arrow O2_V1_34.zip
S@ber_Chopper
Actif
« Répondre #27 le: 07 Août 2009 à 23:48:59 »
Ah cool enfin le support des images je test pour mes flac un miracle depuis le temps que j'attend cela.
on dit merci à odey encore une fois pour une bonne traduction comme d'hab j'attend toujours ta maj même si je fais la maj avant.
Edit d'Odey : des fois, je suis tellement débordé que je ne vois pas une nouvelle mise à jour... alors un piqure de rappel ça fait pas de mal ! Wink
« Répondre #28 le: 06 Septembre 2009 à 17:32:26 »
Le firmware V1.35 version finale est disponible sur le Cowon O2 sur le site en corée. Voici le détail des modifications apportées.
(J'ai mis en jaune les modifications que j'ai remarqué depuis la V1.34 béta)
Movie Player
(Certains du contenus Megastudy pour étudiant / Correction des phénomènes de clignotements)
Ok Amélioration de la prise en charge de la lecture des codecs AVI endommagés
Ok Amélioration de la capacité à changer une couleur anormale de sous-titre
(Correction des sauts d'images, pendant que la lecture des vidéos Divx)
Ok Amélioration du systeme de recherche sur les fichiers AVI volumineux
Ok Correction des sauts de son sur les fichier mpg
Music Player
Ok Amélioration de l'affichage des tags (l'information semblait être corrompue à la fin si le texte était trop long)
Ok Stabilisation du multi-tâches musique et photo / visionneuse comics. Correction des comportements anormaux
en fin de lecture d'une fichier musical.
Ok Faites glisser et scroller grâce au stylet
Ok Pendant la lecture de musique ou de films, la liste s'ajoute au programme utilisateur stockés dans la liste des fichiers récents
Une liste des fichiers récents dans le programme utilisateur au moment de l'exécution permet de rajouter son fichier et ainsi modifier
la liste de lecture courante.
Plus
Ok Correction du temps anormal de latence lors de l'extinction de l'appareil.
Ok Changement de position des réglages de mise en sommeil [Réglage "power"] sur l'icône horloge en bas.
* Notez qu'il n'est plus possible de rétrograder de firmware après une mise à jour de celui-ci.
Téléchargement Arrow O2_V1_35.zip
« Répondre #29 le: 08 Septembre 2009 à 14:38:47 »
Voila c'est fait la version 1.35 estampillée internationale viens enfin d'être mise à disposition sur le site Cowon.
C'est l'occasion pour moi de retraduire un peu plus proprement les améliorations apportées pour ce firmware.
Mode Vidéo
Ok Correction de l'erreur de clignotement de couleurs floues pendant la lecture de fichiers vidéo encodés en WMV9 Simple Profil.
Ok Correction de l'erreur de non prise en charge de codec sur certains fichiers AVI, qui présentent une en-tête endommagée
Ok Amélioration de l'affichage couleur et des sous-titres anormaux.
Ok Correction de l'erreur sur certains ASF / WMV qui ne ne sont pas lus correctement à cause d'une mauvaise détection du temps de lecture
Ok Amélioration de la stabilité du décodage des fichiers MPEG4.
(Correction de l'erreur d'arrêt du système pendant la lecture de certains fichiers DivX)
Ok Correction de l'erreur sur l'imposibilité de rechercher vers des portion de fin sur quelques fichiers AVI volumineux.
Ok Correction de l'erreur de coupure de son régulière pendant la lecture de certains fichiers mpg.
Mode Musique
Ok Support BMP, PNG, GIF, TIFF et formats d'image pour les album arts.
Ok Supporte jusqu'à à 59.0 méga pixels en JPG et 5.0 méga pixels sur les autres formats pour les arts album.
Ok Amélioration de la stabilité de lecture des fichiers MP3 contenant des album arts.
Ok Amélioration de la stabilité de lecture des fichiers MP3 qui contiennent les balises ID3.
(Correction d'erreur sur certains fichiers MP3, dont les étiquettes ID3-tête était de 0 et qui dont la lecture était anormale).
Ok Correction de l'erreur d'affichage des tags ID3 de manière rompue quand la longueur des tags ID3 était trop longue.
Image / Comics Viewer
Ok Support des fichiers BMP qui sont 16Bit RGB565.
Ok Correction d'erreur de plantage du système lors de la lecture de fichiers dont le nom est trop long.
Ok Correction de l'erreur d'affichage de la première image après une redémarrage du système.
Ok Correction de l'erreur d'affichage anormale de certains fichiers JPEG en clair ou ou plus foncé.
Ok Fixed the error that images were not moving properly when music is off in multi-tasking pop-up.
Ok Correction de l'erreur de changement incorect d'image pendant que la musique est éteinte en mode multi-tâches.
Navigateur
Ok Support de défilement par glisser.
Fichiers Recents
Ok Correction de l'erreur de plantage lors de la lecture de musique en même temps que plusieurs fichiers texte sur la carte SD à partir de la liste des fichiers récents
Ok Changement de la sauvegarde des fichiers récents consultés dans le dossier des fichiers récents lorsque vous exécutez des programmes des utilisateurs.
Auparavant, c'était enregistré comme fichier récent quand vous allez sur la liste des programmes utilisateur.
Paramètres du mot de passe
Ok Ajout de nouvelle fonctionnalité d'ajout de mot de passe pour protéger vos fichiers.
(Pas de protection mot de passe lorsque vous vous connectez votre appareil au PC.)
Ok Utilisez cette fonction après avoir fixé les paramètres. (Setup > System > Function)
Ok Le mot de passe peut contenir de 1 à 8 chiffres.
Ok Pour supprimer mot de passe, connectez votre appareil avec un ordinateur et supprimer le fichier password.sys dans le dossier .system de votre appareil.
Divers
Ok Correction de l'erreur d'affichage incorrect de l'horloge lorsque vous changez de certaines polices.
Ok Correction de l'erreur qui retardait la mise hors tension de façon inhabituelle.
Ok Changement de réglage de la minuterie sommeil en cliquant sur l'horloge dans la barre inférieure.
* Veuillez noter qu'il n'est pas possible de downgrader le firmware après mise à jour de votre appareil avec ce firmware.
Téléchargement Arrow O2PMP_V1_35.zip
Guide du mot de passe
Pages: 1 [2] 3 Haut de page Imprimer
